The cookie settings on this webpage are set to ‘allow all cookies’ to give you the very best experience. If you continue without changing these settings you consent to this - but if you want to you can change your settings at any time at the bottom of this page.
Cookies are very small text files that are stored on your computer when you visit some websites. We use cookies to make our website easier for you to use. You can remove any cookies already stored on your computer, but these may prevent you from using parts or our website.
Check which broadband packages are available in your area?
Let's check if you can get {{packageName}}?
Your home details will help us check which you're able to get.
Please enter a valid postcode
Please enter a valid landline number
I don’t know my landline number Enter my landline number
Check now
Please select your address below
  • Sorry, we don’t have any addresses that match your query.
Can’t find your address? Get an estimate just using your postcode
We can't check your products online.
Please call us on 0800 100 400 to talk about products or your upgrade options.
It looks like you don't have BT Broadband.
Why not check out our great Broadband Packages?
{{resultDetailsHeading.telephone}}
{{label}} † Factors affecting individual lines may mean that in a very small number of cases, broadband service may not be available. BT will always try to provide service but will advise you if this is not possible
More about your line speed Hide results
You could get
Fibre broadband
{{estDownloadRange}} Estimated download speed* range
{{minGuaranteedSpeed}} Lowest assured download speed*
{{estDownloadSpeed}} Estimated download speed*
Or
Standard broadband
{{copperEstDownloadRange}} Estimated download speed range*
{{copperMinGuaranteedSpeed}} Lowest assured download speed*
More about these speeds Less about these speeds
Estimated speeds
* BT always offers you the best speed possible on your line. Typically 80% of customers receive speeds within or above this range. The speed prediction we have given here is an estimate, however download speeds can vary and the actual download speed will fall within a range. The BT broadband range is an indication of the speed that other similar lines across the UK have achieved for their broadband service.
The actual speed depends on several factors such as the product option you choose, the processing power of your computer, how many people are using your broadband connection at the same time, whether you use a wireless or cable connection, the speed of the websites that you visit and the performance of our network. Speeds to be lower at peak times – peak times are evenings and weekend.
In the first ten days you may see your speed go up and down. When using a postcode only (rather than a telephone number) the checker results are less accurate. We use a best guess of where you live based on the centre point of the postcode and not the exact routing of the line to your address, and so the result must be treated with caution.
Where we’re able to provide a date for future fibre availability, it is indicative only and subject to change.
We'll let you know when BT Infinity fibre broadband is available in your area
BT Infinity is available in your area but due to a high demand there is currently no capacity left at your local cabinet. There will be a waiting period until we can activate the service.
Register your interest in BT Infinity
By giving us your details, you give us permission to keep you informed about BT Infinity by email
Read about the fibre optic roll-out
Thank you!
As soon as we know when you can get BT Infinity we'll email you at:
{{txtRiEmail}}
{{product.name}}
{{product.description}}
Or
We're checking what products you can get. This shouldn't take long.
We're just checking if you can get {{packageName}}. This shouldn't take long.
Frequently asked questions
  • {{tab.tab_title}}
{{question.question_title}}
See all questions
