BT Home Products
Upgrade your wi-fi
Get the NEW BT Smart Hub
The UK's most powerful wi-fi signal vs major broadband providers
Turn your home into wi-fi heaven with the new BT Smart Hub. It's designed to give you reliable wi-fi – even in those hard-to-reach rooms.
- Better wi-fi coverage
- More reliable connection
- Next-gen wi-fi for superfast speeds
SAVE
£64
.99Δ
Full details
Brilliant home wi-fi has arrived
Thanks to its massive power and clever tech, the BT Smart hub can make a huge difference to getting online at home.
It's designed to give super-reliable wi-fi signals. So people can watch BT TV, stream videos and go online gaming – all at the same time. Those wi-fi signals go a long way too, so you can get online easily with a fast and reliable connection.
Powerful wi-fi
The all-new BT Smart Hub has the power to give you wi-fi even in hard-to reach rooms.
Superfast wi-fi
The BT Smart Hub uses next-generation wi-fi standards to give you massive speeds.
Get future-proofed
The BT Smart Hub could support many home appliances as they become wi-fi enabled
The helpful hub
If the BT Smart Hub spots a problem, it will quietly reboot and make a fresh connection.
Do more with a Home Hotspot 600 Plus Kit
Supersize your wi-fi
Here's a great way to extend the reach of your home wi-fi. Just add a Home Hotspot 600 Plus Kit. It's a powerful wi-fi signal extender that works beautifully with the BT Smart Hub.
- Wi-fi in more places
- Fully compatible with most hubs
Save
50%
v RRP
Full details
Want wi-fi in more places?
Now you can extend the reach of your home wi-fi. The Home Hotspot 600 Plus Kit sends your home hub's wi-fi signal through your electricity lines, then broadcasts again to cover those hard-to-reach places.
You can use as many Home Hotspot 600 Plus Kits as you like, and build your home wi-fi so it covers every area you want.
Use your Home Hotspot 600 Plus Kit to get wi-fi where you want, Maybe in the garden...
Fully compatible
The Home Hotspot 600 Plus Kit works brilliantly with most hubs, particularly the BT Smart Hub.
Smart tech
The Home Hotspot 600 Plus Kit uses your home's mains electricity to carry you wi-fi signals.
Keep on adding
You can add as many Home Hotspot 600 Plus Kits as you like to build a big, reliable network.
Home Phones
BT8600 blocks up to 100% of nuisance calls
Saving up to
42%
for BT customers only- Block up to 1000 specific numbers
- Block calls by number and type
- Store up to 60 mins of messages
- Automatically copy contacts between handsets
How many handsets do you need?
Exclusive price for BT customers only
1 handset
2 handsets
3 handsets
4 handsets
£3.99 delivery charge
Please tick appropriate box above
Full details
- Brilliant features
- More on BT8600
- Block 100% nuisance calls¹Never speak to Nuisance callers again. Powered by award winning trueCall technology, all incoming calls not on your contact list are asked to announce their name so you can decide whether to accept or reject them.
- See who's callingThe BT8600 shows you the number calling so you can choose when to pick up. Just add BT Privacy and Caller Display to your plan.
- Auto copy ContactsAutomatically copies contacts between handsets, so you always have the right number to hand without having to enter it more than once. Enter up to 200 contacts.
- Plenty of storageThe built-in answer machine has a large memory with space for up 60 minutes of messages. Enough for the busiest of households.
- 1. To block nuisance calls, you'll need the Caller Display service to be active on your account. You can get this service FREE for 12 months by activating it in My BT.
More on the BT8600
- Choose to block International, Witheld, or unknown calls
- Save up to 200 names and numbers
- 21 hour talk time and 240 hour standby time
- Easy set up with screen prompts to guide you through the process
- Available with up to four handsets
- One touch call blocking
BT2700 Nuisance Call Blocker
- Blocks up to 50 numbers
- One touch Do Not Disturb button
- Handsfree facility
1 handset
2 handsets
3 handsets
4 handsets
Full details
- Product description
- Do not disturbPress one button and all calls are sent straight to your answer machine.
- Copy contactsEnter your contacts once and share between handsets so you'll always have the right numbers to hand.
- Answer phone20 minutes of message storage so you'll never miss that important call.
- Handsfree speakerChat away even when you’re busy with the handsfree speaker.
- Block Nuisance callsBlocks up to 50 individual numbers*
- * You'll need a Caller Display service from your network provider to block nuisance calls. Charges may apply.
More on the BT2700
- Large, clear 1.6" colour screen that's easy to read
- Shaped to give great sound quality so you hear every word
- 12 hour talk time and 120 hour standby time
- Save up to 50 names and numbers
- Records up to 20 mins of answer machine messages
- Handsfree Speaker
- Block up to 50 numbers
Video Coming Soon
Home Connectivity
Complete coverage with Whole Home Wi-Fi
Super smart
Three discs create a complete Wi-Fi network all around your home. Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
- Easy set up with our dedicated app
- See who’s online
- Temporarily “Pause” the internet – great for meal times or bed time
Full details
Want Wi-Fi all around your home?
Perfect for larger homes, Whole Home Wi-Fi from BT creates a complete Wi-Fi network using 3 discs that you position around your home – which means no more dead spots.
Whole Home Wi-Fi works with all Hubs, and is easy to set up using the Whole Home Wi-Fi app available from the App Store or Google Play.
Simple set-up
Use the app to guide you through our easy set up process, includes help to find the greatest positions for your discs to get the best Wi-Fi
Super smart
Complete control
Temporarily pause your Wi-Fi via the app so you’re in charge.
Simple dashboard
Use the dashboard to see who is online and what devices are connected to your Wi-Fi.
Dual-Band Wi-Fi Extender 610
- Extend your existing wi-fi coverage to areas your router can't reach
- Works with all Broadband providers
- Upgrade to dual band wi-fi for a more reliable connection
BT CustomersSave
25%
vs RRP
RRP £39.99 £29.99
Buy the Wi-Fi Extender 610Full details
- Boost your wi-fi signal at homeAre there places in your home where your wi-fi just won’t go? It’s easier than you think to fix. Simply plug in the Dual-Band Wi-Fi Extender 610 within range of your wi-fi and it'll boost the signal further around your home. Dual-band means that there is a second separate wi-fi signal that your devices can connect to giving you faster downloading, streaming and browsing.
- Internet (works with any broadband)
- Wireless Router
- Dual-Band Wi-fi Extender 610
- Extend the range of your wireless broadband where your router can't reach
More on the Dual-Band Wi-Fi Extender 610
- High speed data transfer (N600)
- Simply push one button to connect to your hub or router
- Dual-band wireless technology for a better connection
- Enables multiple HD or 3D video streaming
- Compatible with non dual-band devices
Broadband Extender 600 Kit
- Turn any power socket into an Ethernet port
- No installation - just plug and play
- Works with any broadband provider
BT CustomersSave
17%
vs RRP
RRP £29.99 £24.99
Buy the Broadband Extender 600 KitFull details
- Get the complete broadband experiencePerfect for connecting wired devices like Smart TVs, laptops and online gaming consoles in a different room to your router, this broadband extender provides a solid connection to the internet.
It's really easy to use, connect one unit to your hub and plug in the other unit into any socket where you need an internet connection.
- Router
- Broadband Extender
- Plug the Broadband Extender into any power socket in the home and connect to any device via an Ethernet cable
More on the Broadband Extender 600 Kit
- Compatible with other AV HomePlug powerlines
- Fast data transfer for downloads, streaming or online gaming
- Ethernet port for wired connections
- No installation – just plug in for instant internet access
BT Mini Connector Kit
- Connect your BT TV box to your BT Hub Works with all Hubs
- Supports On Demand, Catch Up and
- Extra TV Channels through BT TV
BT CustomersSave
44%
vs RRP
RRP £89.99 £49.99
Buy the BT Mini Connector KitFull details
- Connect your BT TV box to your HubBT Mini Connectors allow you to connect your BT TV box to your BT Hub. They work with all our Hubs, without having to run an Ethernet cable all the way around the home. They do this by sending your broadband signal through the electrical wiring in your home.
More on the BT Mini Connector Kit
- Works with all Hubs
- Pack of 2 connector plugs
- Includes pass through socket so you don’t lose a plug
- 2 Ethernet ports on each connector
- Supports On Demand, Catch Up and Extra TV Channels through BT TV
- Work with speeds of up to 1GB
- Can be used with Ultra HD
- Makes it easy to self install BT TV Ultra HD without the need for an engineer visit
BT Mini Connector Add-On
- Extend your wired connection even further with the Add-On
- Works with BT Mini Connector Kit
- 2 Ethernet ports
Full details
- Boost your wired connection even furtherThe Mini Connector Add-On allows you to extend your wired network even further around your home. By adding this additional Connector to your existing BT Mini Connector Kit you can connect more wired Devices such as games consoles to make the most of your broadband all around your home. By having the power socket on the front of the connector it also means you never lose a plug socket on your wall.
More on the BT Mini Connector Add-On
- Single unit Add-On connector to be used with BT Mini Connector Kit
- 2 Ethernet ports for wired devices
Baby Monitors
Baby Monitor
400
- Digital HD sound
- Sound sensitive LEDs – for visual alert
- 300m range outdoors and 50m indoors
Full details
- Peace of MindThe Audio Baby Monitor 400 has a long range of 300m outdoors and 50m indoors, so you never miss a sound whether you’re in another room or even in the garden.
- HD SoundOur interference free HD crystal clear sound means you’ll always know when your little one’s upset.
- Visual AlertsSound level lights are for when you don’t want to hear every snuffle but want to be alerted if they need you.
More on the Audio Baby Monitor 400
- Interference free Digital HD sound so sensitive you can hear your baby breathing
- Long range of 50m indoors and 300m outdoors so you don’t miss a sound
- Sound sensitive LEDs for visual alerts
Baby Monitor
450 lightshow
- Adjustable Nightlight
- Star and Moon Lightshow
- Two-Way Talk Back
BT CustomersSave
20%
vs RRPRRP £49.99 £39.99
Buy the Baby Monitor 450 LightshowFull details
- Lightshows and lullabiesA soothing ceiling light projection and a choice of 18 lullabies, nature sounds and white noise will help your baby drift off to sleep.
- Night lightAdjustable night light provides reassurance for your baby and helps you find your way around your baby’s room without turning on the main light.
- Huge monitor rangeUp to 300m outdoors and 50m indoors, so you never miss a sound whether you’re in another room or even in the garden.
More on the Audio Baby Monitor 450
- Star and moon projected lightshow
- 18 lullabies
- Adjustable night light
Video Baby Monitor
2000
- 2 inch video screen
- Night Vision
- Manual Pan and Tilt
BT CustomersSave
25%
vs RRPRRP £59.99 £44.99
Buy the Video Baby Monitor 2000Full details
- Adjustable video screenHigh quality 2 inch screen with manual pan and tilt means you never miss a moment, as you can adjust the monitor to your convenience.
- Night VisionHelping you keep an eye on your baby even when it’s dark, without waking up the little one
- Huge monitor rangeLong range of up to 250m so you never miss a sound when you aren’t around
More on the Video Baby Monitor 2000
- 2 inch colour screen
- Night Vision
- Manual pan/tilt with zoom
- Long range of up to 250m so you don’t miss a sound
- Portable parent unit so you can move freely around your home
Video Baby Monitor
3000
- 2.8 inch video screen with Night Vision
- Two-Way Talk Back and Lullabies
BT CustomersSave
25%
vs RRPRRP £79.99 £59.99
Buy the Video Baby Monitor 3000Full details
- Adjustable video screenHigh quality 2.8 inch screen with manual pan and tilt means you never miss a moment, as you can adjust the monitor to your convenience.
- Lullabies and talk-back5 lullabies and two way talk-back to help your baby drift off to sleep.
More on the Video Baby Monitor 3000
- 2.8 inch colour screen
- Night Vision
- 5 different lullabies to ease your baby to sleep
- Two way talk-back
- Temperature display
Frequently asked questions
- {{tab.tab_title}}
{{question.question_title}}
See all questions
Important information
- {{tab.tab_title}}
