The cookie settings on this webpage are set to ‘allow all cookies’ to give you the very best experience. If you continue without changing these settings you consent to this - but if you want to you can change your settings at any time at the bottom of this page.
Cookies are very small text files that are stored on your computer when you visit some websites. We use cookies to make our website easier for you to use. You can remove any cookies already stored on your computer, but these may prevent you from using parts or our website.
The BT Reward Card is simple and easy to use. We load it up with money, and you can spend it on things like everyday purchases or shopping.
How does the BT Reward Card work?
It’s preloaded with money, so you just need to activate it and then you can start spending
It can be used at millions of places across the world (in most places with a Mastercard® logo). There are just a few exceptions that are stated in the T&Cs below
It uses Chip and PIN, so it’s more secure than spending cash
BT Reward Card
Claiming your reward couldn't be easier:
  • Order you broadband online at BT.com and check it’s installed
  • Go to www.bt.com/claimmyreward to log in and claim your reward using your BT ID
  • We’ll post your reward within 30 days if you’re successful
Frequently asked questions
  • {{tab.tab_title}}
{{question.question_title}}
See all questions
